Discussion topic: Help please
This message was authored by: Anthea47
Help please
No satellite signal on my Sky+HD box
Re: Help please
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: Help please
@Anthea47
And calling on the services of a local satellite company will be at your own expense.
