Discussion topic: Hard DIsk Drive
This message was authored by: PaulH6688
Hard DIsk Drive
Message on screen " There is a problem with your Hard Disk Drive"
I have followed the instructions on screen but fault still not resolved
Re: Hard DIsk Drive
@PaulH6688  Your post has been moved from the accessibility board as this isn't related to Sky's accessibility services.
Which box are you seeing this message on Sky+HD or Sky Q
Avatar for PaulH6688
Level 0 icon
Re: Hard DIsk Drive
Message appears on Sky + HD
Level 0 icon
Re: Hard DIsk Drive
Not helpful in the slightest considerin* no response given
Re: Hard DIsk Drive
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Also
This forum is primarily customer-to-customer help, you're not talking to Sky support, we respond in our own free time so you need to be patient
Re: Hard DIsk Drive
You do need to wait for a reply as this is a customer helps customer community not a live chat service.
The first troubleshooting step is to restart the box by switching it off at the mains, waiting a minute, and then switching it back on. If the error persists, attempting a full system reset may help, though this will permanently delete all recordings, downloads, purchases, reminders, and series links. It is important to note that resetting the hard drive does not guarantee a fix if the drive itself is physically damaged.
If the drive is damaged your only option will be to move to SKy Q or Sky stream as Sky+HD is a legacy system and is no longer supported by Sky.
This message was authored by: HeathHayle
Re: Hard DIsk Drive
or get someone to replace the hard drive
= Sky+ SD boxes x4 (pace bskyb 3100) ===
