Discussion topic: Fix my sky dish
Message posted on 07 Jul 2026 02:24 PM
Fix my sky dish
I live in a block of flats. There's some building work going on at the moment. The scaffolders have knocked the sky dish and my sky now won't work. I need to get it fixed.
Message posted on 07 Jul 2026 02:28 PM - last edited: 07 Jul 2026 02:34 PM
Re: Fix my sky dish
@KellyMenendez Sky+ where you posted is no longer supported by Sky.
In addition if it's a block of flats is it your own dish or a communal dish? If the former and you habve Sky+ you need to employ the services of a local installer, if the latter speak to the building managemnt as they will be responsible for any communal setups.
Message posted on 07 Jul 2026 02:29 PM
Re: Fix my sky dish
Sky don't carry out work on satellite dishes for Sky+ (where you've posted). You will need to employ a local satellite company at your own expense.
