Discussion topic: Faulty sky box
This message was authored by: Robert184
Faulty sky box
Box turns on no picture
Re: Faulty sky box
Turn your Sky box and your TV off at the plug. Disconnect the HDMI cable from both tv and box, swap the ends over and plug back in.
Turn on both your Sky box andytv at the plug. Make sure the box's power light is green, and check the correct HDMI input is selected on your tv.
