Discussion topic: Fault
Message posted on 02 Jun 2026 09:42 AM
Fault
My sky tv is not working. When watching the screen goes blue and connection is lost
Message posted on 02 Jun 2026 09:49 AM
Re: Fault
@Sarah2165 switch the box and ypur tv off at the plug. Unplug the HDMI cable between your Sky box and tv. Turn the ends over so that the plug that used to go to the tv, now goes to your Sky box. Wait a couple of minutes, then restart your Sky box and tv.
Message posted on 06 Jun 2026 10:50 AM
Re: Fault
Id certainly Recommend turning off for 5 minutes and then on again, however it is worth pointing out that Sky + is a legacy product and as such is no longer being supported by Sky. Have you cosnidered upgrading to Sky stream ?
Sky Full Fibre 500mbps
