24
Discussion topic: Failed recordings -technical fault -10 (100)
This message was authored by PeteJH56 This message was authored by: PeteJH56
trying to download via Catch Up on Sky Witness and although it starts to downlaod after a few seconds it becomes "Failed -technical fault -10 (100)". Although I can download to my laptop via Sky Go, this is far from ideal.
I've tried restarting the sky+ box, rebuilding the planner, all to no avail.
Other recordings and downloads all seem to complete without issue.
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: Failed recordings -technical fault -10 (100)
This message was authored by Mishelly This message was authored by: Mishelly
Grimm sky max wont Dowland yet its been fine al werl downloading apart frim today 16th oct
I've been rewatching Grimm with my daughter foe past few wks then today 16th October it's won't download keeps saying failed I've tried everything from changing from uhd to s.d then rebooting my router even connected my sky through ethnic instead of WiFi turned everything off and nothing works everything else downloads but not sky max . Lil pead off know like bcz there nothing else to watch
This message was authored by Grovey75 This message was authored by: Grovey75
Re: Grimm sky max wont Dowland yet its been fine al werl downloading apart frim today 16th oct
I'm having the exact same problem with grimm. I've been watching fine until last episode in series 5 it will not download gets stuck at 101% cant view it or anything, I tried the first episode of series 6 and its still the same
This message was authored by Daniel0210 This message was authored by: Daniel0210
There is an issue with downloading at present on Sky Q and Sky+ platforms which Sky have been made aware of.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Really? Shouldn't they put something on the site so people know lol I thought I was going crazy or something, good to know thanks, guess I'll keep checking to see when fixed
This message was authored by DancerShaper This message was authored by: DancerShaper
I am having exactly the same problem with box set downloads but catchup tv content seems ok
Thankyou Annie
PeteJH56
Hi Annie - sorry, but this doesn't help. there nothing wrong with my broadband service or equipment - otherwise the issue would be more widespread.
???????????????????????????? Did you not follow my link?
Annie( I am Neurodivergent ) - Sky Plus FAQ - Sky Stream FAQ
I take it you haven't seen the posts about the ongoing issues at present which is nothing to do with your broadband or equipment:
https://www.sky.com/help/servicestatus/tv
We are aware that users may receive a technical error message when downloading some content on their Sky Q/HD boxes. We are investigating this issue and apologise for any inconvenience caused.
This message was authored by LizzieN This message was authored by: LizzieN
Having the same issue... ☹️  Frustrating as on day off and had planned to spend the day catching up on my shows... Oh well housework instead 😭Thanks for the info
This message was authored by Vviicckkyy This message was authored by: Vviicckkyy
I have had the same problem, thought I was going mad have reset the a box and the broadband and everything in between - is this likely to be fixed soon?
This message was authored by Kirsty+S27 This message was authored by: Kirsty+S27
Posted by a Sky employee
Hi @Mishelly
I merged your post into this thread as the issue is linked to what @Annie+UK advised. This is an issue we are of and it's being investigated.
Thank you.
Kirsty
Community Manager
This message was authored by GILLYBABY This message was authored by: GILLYBABY
@Kirsty+S27 is this going to be another issue that rumbles on forever like the stacking issue
The service status message for failed downloads  is woefully inadequate and mentions broadband..as if its specific to me..nothing wrong with my bband?
Seems nobody actually gives a damn about the user experience at Sky.  Just take the cash and run.
Nothing personal to u of course.
On average, new discussions are replied to by our users within 100 minutes
