Discussion topic: Does a Sky + box reqire a communal (standard) ariel ?
Message posted on 14 Nov 2023 04:13 PM
Engineer turned up to upgrade my Sky + box to Sky Q, but informed us it wasn't possible in our location, however, the communal ariel was down, and he informed us that it would have to be repaired before the box would work. Strangely, our next door neighbour has had Sky + for 10 years without a communal ariel.
Any advice would be appreciated.
Message posted on 14 Nov 2023 04:39 PM
Re: Does a Sky + box reqire a communal (standard) ariel ?
Unless you have your own satellite dish, you're reliant on the communal dish, I'm afraid.
Message posted on 14 Nov 2023 04:58 PM - last edited: 14 Nov 2023 05:04 PM
They either have their own satellite dish or access to a communal signal distribution system attached to a dish (note: not an 'aerial', which is a collection of bent wire used for Digital Terrestrial television rather than Sky satellite television)
Sky Q uses a different reception system to Sky+, and it's certainly possible for a communal system to be compatible with Sky+ but not Sky Q
Message posted on 15 Nov 2023 11:14 AM
When I say a communal ariel, I mean a digital terrestrial ariel which the engineer said I needed for the box to work, yet my neighbour has never had one in 10 years. Its all very misleading ?
Message posted on 15 Nov 2023 11:19 AM
A "Digital" terrestrial aerial is for Freeview TV not satellite.
You need a dish either your own or Communal (commonly referred to as an IRS setup)
Not sure why the engineer told you you need an aerial as they should really know the difference between the 2.
Message posted on 15 Nov 2023 11:26 AM
@Crabit wrote:
When I say a communal ariel, I mean a digital terrestrial ariel which the engineer said I needed for the box to work....
Not for a Sky TV box.
For Sky TV, you need access to a satellite dish, either your own, or a communal dish.
Or for Sky Stream TV you need access to good broadband, but neither a dish nor an aerial is required.
Message posted on 16 Nov 2023 01:00 PM
Simply not true for Sky satellite television hardware or service. It would however have been the case for a BT TV box, where live content arrived over broadcast DTTV.
