Discussion topic: Constantly getting message ‘Sky Box not getting satellite signal
This message was authored by: GM8
Have been getting this message constantly over the last few days and have had the same problem many times previously. Understand bad weather plays a part but this is so bad that I'm thinking of leaving after 30 years as a customer.
I find  it really frustrating when channels 101, 102, 103, 104, 105 (HD channels) experience this problem yet channels 801, 802, 803, 804, 805 (non HD channels) work fine. So clearly my Sky Box is getting a satellite signal just not HD signal.
Re: Constantly getting message ‘Sky Box not getting satellite signal
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and other not)
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
There's a problem with your dish setup. It's entirely possible to receive some channels perfectly, while getting a 'no satellite signal' on others, whether they're HD channels or not. It's a shame you haven't spoken to Sky about it previously, as they would have been able to send an engineer who would have fixed it. Unfortunately, Sky are no longer providing engineer support for Sky+, (unless you have Sky Protect) so you would either need to engage a local satellite engineer, or upgrade to Sky Q.
This message was authored by: SB5323
Been getting this today,on both boxes,problem with viewing card on both my boxes with different card numbers
Happens a lot after bad storms
