8
This discussion topic has been answered Discussion topic: Code needed for Sky+HD remote rev.10
This message was authored by: Decoder
Need a code for Sky+HD Remote for Bush VL32HDLED purchased form Argos.
This message was authored by: Mark39 Answer
Re: Code needed for Sky+HD remote rev.10
Avatar for Decoder
Thanks Mark39 but I have already tried that link and none of the codes supplied work. The problem stems from the fact that although the TV is branded as Bush by Argos the actual company no longer exists.
The tv's are produced for Argos by another company, probably Chinese and simply bare the Bush logo. I've tried all the codes for probable companies such as Vestel, Alba and many more, but without success.
Programme remote when you cannot find the correct code:
    1. Press TV
    2. Press and hold Select and Red together until the red LED flashes twice.
    3. Press TV, then Standby repeatedly until the TV switches off. As soon as it switches off, press Select to save the code.
Avatar for Decoder
Thank you Annie+UK.
Tried this method with partial success. Got the volume to work but it only works on the Channel button, not on the Volume button as you would expect.
Incedently the codes I've found to be working though not as expected with the Bush VL32HDLED from Argos are 2193, 2267 and 3095.
Avatar for Decoder
Forgot to mention that the above codes are working albeit partially on the Sky+HD Rev. 10
This message was authored by: no-thank-you
It says: "We no longer provide the codes that allow Sky+ remotes to control the volume on your TV"
How to program your remote control with no code.
Take a look at the link below:
See question Q43 in my Sky Plus F⋅A⋅Q
That link was posted by @Mark39 more than two years ago: since then Sky has essentially ceased to offer support for the HD platform
