Discussion topic: Card in sky box not working
This message was authored by: Chriscol1
Please need you to switch on my card in my second box
Re: Card in sky box not working
What error message are you seeing? Do you have a Multiscreen subscription?
This message was authored by: Mandy114
Message coming up no signal  when trying to connect to sky
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
No signal  message on tv screen
