Discussion topic: Cable wire into sky+hd loose
This message was authored by: dtomo
Can't get on demand on sky+hd box, intermittently last few days, had a look behind box and a dual wire has come out of one of the connections at the back. I reconnected it ( not sure if correctly) but now on signal  input 2 signal strength quality aren't on and lock indicator shows not locked
how can I fix it
Re: Cable wire into sky+hd loose
Youtube has videos on how to reattach the plug to the cable
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for dtomo
Thanks I'll have a look
https://www.youtube.com/results?search_query=f-connector
It needs fixing, but it won't make any difference to the On Demand problem which relies on a broadband connection, not the dish cables..
Avatar for dtomo
Found the video on you tube which sorted the input 2 problem, thank you
I still had problems connecting to on demand search and catch up so rebooted my internet, still didn't work even though it was saying connected.
In the end I deleted the internet and reset it again which seemed to have sorted everything and I downloaded the programme I wanted.
30 minutes later it's playing up again 🙈🤷‍♀️
