Discussion topic: Blue Screen Appearing every 10 seconds for about 2 seconds
Message posted on 13 Sep 2026 02:29 PM
Intermittently I get a blue screen appearing every 10 seconds for about 2 seconds duration. This interrupts the programme and makes it unwatchable.
Message posted on 13 Sep 2026 02:35 PM
Re: Blue Screen Appearing every 10 seconds for about 2 seconds
@SquareeyedJ ...and this is on Sky+? Or do you have Sky Stream/Glass or Sky Q?
Message posted on 19 Sep 2026 06:16 AM
i have same issue on sky hd box
Message posted on 19 Sep 2026 08:02 AM
@bettyboop67 turn your Sky box off at the plug and put your tv in standby. Disconnect the HDMI cable from both your tv and Sky box, swap the ends over and reconnect it. Then restart your Sky box and check whether it's ok.
