Discussion topic: Aerial splitter advice
Message posted on 04 Feb 2024 08:44 AM
Currently have Sky+ HD where main aerial feed goes into sky box then to tv by hdmi. We also use rf output to a splitter to feed aerial to bedroom TVs. Upgrading to sky q which does not have rf output. Does anyone have any advice please - we are getting mini boxes for tv bedrooms. Thank you in advance for any help
Message posted on 04 Feb 2024 09:03 AM
Re: Aerial splitter advice
The Mini boxes will take the place of your current RF connection (and provide much a much better picture and sound). You'll be able to do away with the splitter and RF (aerial) cables.
Message posted on 05 Feb 2024 05:29 AM
@Mark39 Thank you!
So if I understand correctly the mini boxes will pick up the digital aerial feed over WiFi for the regular bbc itv and freeview channels?
Do I need to worry about aerial feed to main tv at all?
Apologies if I am being a little dense here!
Annieh
Message posted on 05 Feb 2024 09:06 AM
@AHawk your Sky Q box and the Mini boxes can receive all the Freeview channels that you're currently receiving via your TV aerial, so you don't need an aerial feed to your main TV.
You could, if you wanted to, keep the feed from your TV aerial just in case of a problem with your Sky Q box.
Message posted on 05 Feb 2024 10:00 AM - last edited: 05 Feb 2024 10:01 AM
Satellite dish feed rather than ' digital aerial feed '
The main Q box receives the broadcast signal for all the live broadcast channels which the satellite cluster carries, and retransmits the selected content to one or more Mini boxes: this includes the PSB and other free to air services.
An 'aerial' is not relevant to Q: as @Mark39 indicates, you could choose to attach it to the digital terrestrial tuner in a television set.
