- Mark as Read
- Report comment
GSherwood99
What is the Sky remote app?
The Sky remote app makes it easy to control your Sky Glass or Sky Stream straight from your phone or tablet!
What do I need to get started?
To use the Sky Remote app, you’ll need:
- A Sky Glass or Sky Stream device connected to the same Wi-Fi network as your phone or tablet.
- A compatible mobile device.
- The Sky Remote app, available on the App Store or Google Play.
How do I download the Sky Remote App?
For Apple devices
- Open the App Store.
- Tap the search bar and type Sky Remote app.
- Tap Get, then Install.
(If you’ve downloaded it before, you’ll see a cloud icon.) - Enter your iTunes password if prompted, then tap OK.
For Android devices
- Open the Google Play Store.
- Tap Search and type Sky Remote app.
- Tap the app, then Install.
- Enter your Play Store password if prompted.
- Tap Accept.
How do I connect my devices?
- Make sure your Sky Glass or Sky Stream is on and connected to the same Wi-Fi network.
- Open the app it will automatically search for compatible devices.
- On first use, select your device. Once connected, the remote will appear.
- Next time you open the app, it will try to reconnect to the last device used.
Make sure you keep your app updated for the best experience and new features!
| What's new in v1.0.7291? | Accessibility Enhancements |
Labels:
Leave a comment
