- Mark as Read
- Report comment
Federica-C
Sky TV on demand is available at no extra cost with any Sky TV bundle. Simply connect your Sky box to your home broadband connection.
If you feel you need to, you can reset your connection using the instructions below.
- Press Services on your Sky remote
- Select the Settings tile
- Scroll across to the Network tab
- Press Select
- Press Red to reset your network connections
Further troubleshooting steps are available here.
Reconnect to the wireless network
- Go back to the network tab using instructions above
- Select ‘Connect with Password’
- Highlight and Select your wireless network.
- Enter your wireless password (this is case sensitive)
Leave a comment
