Fury vs Usyk 2 - Sky Sports Box Office
The next live event being shown on Sky Sports Box Office is Tyson Fury vs Oleksandr Usyk on the 21st December.
If you're a Sky Q or Sky+ customer, you can order the event online from today or use your remote from the 14th December.
If you're a Streaming TV customer, you can only order the event using your remote from the 13th December.
How do I order using my remote?
Sky Q Remote
  • Press Home on your Sky Q remote, select TV guide or Sports, followed by Box Office.
  • Select the event and enter your Sky TV PIN if prompted.
  • You can also buy a Box Office event in the TV Guide or Mini Guide by selecting it and pressing R on your Sky Q remote.
Sky Glass/Stream Remote
  • Press Home on your Sky remote.
  • Select the event from the menu.
  • Enter your Sky TV PIN, if enabled or select Purchase.
Sky+HD Remote
  • Press Box Office on your Sky remote and press Select.
  • Highlight the event you would like to book, then press Select.
  • Press the R button on your Sky remote to record the event.
  • You’ll see a message saying ‘Checking purchase information’ then a message confirming the purchase will be displayed.
Order online at sky.com
Want to order online instead? If you've got Sky Q or Sky+HD you can. With Streaming TV, you can only order using your Sky remote.
To book online:
  • Check your Sky box is connected to an active telephone line, or home broadband.
  • Make sure you have the correct viewing card inserted in your Sky box.
  • Go to sky.com/boxoffice and choose the event you’d like to order.
  • Sign in with your Sky iD email/username and password.
  • Confirm your order.
Good to know: If you order online, you won’t be able record the Sky Box Office event. To record events, you need to order using your remote.
See here for more help.
Note: The event is also available to watch on the Sky Sports Box Office app.
Leave a comment
Comments (1)
