Discussion topic: using two streaming/glass remotes at once
This message was authored by: Anthony_Foster
Message posted on 31 Dec 2025 12:18 PM
I want to use two streaming remotes at once (two locations in room) is this possible? Sky Q will not, the older Sky would
Find out more
Message posted on 31 Dec 2025 01:33 PM
Re: using two streaming/glass remotes at once
'Older' Sky remotes are infrared only: Q, Glass and Stream are Bluetooth and only a single pairing is possible.
This message was authored by: Jon34
Message posted on 31 Dec 2025 03:17 PM
You can use more than one remote at once
You pair one remote using Bluetooth and leave the other remote unpaired, in an unpaired state it will work in infrared
Obviously it needs line of sight to work
