Discussion topic: using the sky stream box with out sky boardband.
This message was authored by: Luke836
I was talking to someone at the sky store in Southampton and I was saying that I have a mobile wil with EE and will the sky stream work from it and he it would is that right that it would work on my EE mobile wifi?
This message was authored by: martswain
Re: using the sky stream box with out sky boardband.
Stream will work with any broadband, however whether your EE service will provide and fast and stable service is going to be the issue.
Have you checked Sky's minimum speed requirements against what your EE router is actually providing to a device?
This message was authored by: usenetz
The Sky Stream puck works fine over WiFi with my EE 5G router.
This message was authored by: DaveDrizen
You say you have  EE mobile WiFi is that 5g broadband or your using a EE mobile phone hot spot. If it the later though sky stream will work with that device, but it a mobile phone the fair use policy usage even though may have a unlimited dater tariff is a lot lower than broadband. There if you using such a device to steam Sky stream you run the risk of breaching EE fair use policy and will be subject to extra charges and restrictions
