Discussion topic: technical problem
This message was authored by: LeaHi
technical problem
Sky stream is saying technical problem. No channel is working
Re: technical problem
Hi @LeaHi have you tried rebooting the puck as this is typically the first thing to try when its not working as expected?
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
