Discussion topic: sky stream
This message was authored by: Rosieleanne95
sky stream
I have a black line across my screen when watching sky stream we have rebooted out puck a few times but nothing works. any ideas on how we can fix this please ?
This message was authored by: martswain
Re: sky stream
Does it happpen with other sources?
Try changing the HMDI cable..
Avatar for Rosieleanne95
Re: sky stream
We have checked it just using Sky its  not the TV. Or any other apps or The HDMI Port
Re: sky stream
If you think your puck is defective you will have to report the issue to Sky and request a replacement☹️
Re: sky stream
Hi @Rosieleanne95 I had something similar on a Glass TV about 2 years ago. A normal reboot didn't help so I left the TV unplugged overnight and the line disappeared and luckily it never came back.
Give it a try tonight but if it doesn't resolve the issue or if it keeps coming back you should call Sky for additional troubleshooting and if necessary a replacement TV (assuming it is still within its 24 month warranty).
Edit - Apologies I see you have a puck and not Glass.  It may be worthwhile leaving leaving your puck unplugged overnight.  Could the problem be with your TV and not a Sky issue or does it only happen while watching through the puck?
