Discussion topic: how to set up sky stream and puck code
Message posted on 03 Feb 2024 08:07 PM
ever since I had this stream tv I have not been able to use it so either come out Monday and sort it out or you can have it back
Message posted on 03 Feb 2024 08:20 PM
Re: how to set up sky stream and puck code
@Flypot60 You're not addressing Sky via the forum, no one will come out as Sky Glass/Stream is a self install system.
Have you called Sky to get help with the setup?
Message posted on 03 Feb 2024 08:27 PM
@Flypot60 wrote:ever since I had this stream tv I have not been able to use it so either come out Monday and sort it out or you can have it back
@Flypot60 what exactly is the error/issue you are seeing?
Message posted on 03 Feb 2024 11:24 PM
@Flypot60 As you have already been advised the Sky Glass TV is self install. The setup instruction should appear on the screen for you to follow. The following links explains the setup procedure and troubleshooting.
https://www.sky.com/help/articles/service-checker-sky-glass-help
If this doesn't help you will need to phone Sky for additional troubleshooting.
Good luck 🤞
