9
This discussion topic has been answered Discussion topic: Voice Control Not Working
This message was authored by: Paul.Oz
For the past few weeks, the voice control function on my Sky Stream puck hasn't been working. I just get the message on screen "Sorry, I didn't quite catch that".
I've tried everything I can think of... restarted puck, replaced batteries in remote, repaired remote and even performed a full factory reset on the puck, but no change.
Anyone else have this issue or any ideas on how I could resolve?
This message was authored by: Fothergill1 Answer
Re: Voice Control Not Working
@Wiley5705  My remote wouldn't accept any voice commands a few days ago and a reboot got it working again.
Settings > system management > Resets & updates > restart device.  It will take about 3 minutes to fully reboot and you will have a blank screen for a couple of minutes until the Sky logo appears.
I hope it works for you 🤞
What command are you giving the Puck?
Avatar for Paul.Oz
Level 4 icon
Any command returns the same message. Some examples:
"Sky News"
"Show me the weather"
"Home"
"Open BBC iPlayer"
"Play House of the Dragon"
Perhaps there's an issue with the remote microphone .... if it was working and now not .... request a replacement remote from Sky🤔
This message was authored by: Wiley5705
Im having the same issue not matter how simple the command is i get the very same response every time. Did you resolve the issue ?
@Wiley5705 Has voice control ever worked for you? Just figuring out if this has stopped working or has never worked...
This message was authored by: JU10
Your answer definitely worked for me. Had similar problem and followed your instructions to restart. Now works perfectly, many thanks.
This message was authored by: Angie2012
This definitely worked for me
This message was authored by: pettycur
Worked for me as well
