Discussion topic: UHD on sky stream
Message posted on 21 Dec 2024 07:23 PM
UHD on sky stream
Is it possible to get UHD sky sports channels on sky stream/puck? I got the 3 months free UHD addition and I've not seen once UHD channel? I'm just wanting it for sports.
thanks
Message posted on 21 Dec 2024 07:33 PM
Re: UHD on sky stream
@BrandonBaker There are 2 full time UHD Sports channels from Sky Sports ME UHD & Sky F1 UHD they should be in the 400s if not they will be down on the 800s on the TV Guide https://www.sky.com/help/articles/tv-channel-list-sky-glass
Message posted on 21 Dec 2024 07:51 PM - last edited: 21 Dec 2024 07:55 PM
You'd need a Sports subscription in addition to the UHD add-on. Even then, relatively few sporting events are actually carried in UHD.
Without Sports, all UHD content is on-demand, not broadcast in an EPG channel.
Message posted on 21 Dec 2024 10:35 PM
I have sky sports on my stream puck? That's why I'm confused because I know on sky Q you get UHD channels (Sky Sports Main Event UHD) for an example.
Message posted on 22 Dec 2024 10:05 AM
With a Sky Sports subscription and UHD add-on, you get Sky Sports Main Event and F1 as linear UHD channels but there are several hidden UHD sports channels. So, if an event is on SS Football or Premier League and isn't showing on Main Event, there will be an on screen prompt if it's available in UHD. Press the on screen button for that and it'll take you to the correct channel.
