Discussion topic: Tv stream box
This message was authored by: Rhysreed
Tv stream box
Wont work and the whole tv is multicoloured.
ive tried all wifi routes but it isnt working
Re: Tv stream box
Hi @Rhysreed
 in order for the community to try and assist you will need to provide more that won't work.... What do you mean by whole TV is multi coloured? What hdmi port is it connected to? And what setting have you set? What TV isdo you use etc etc.
Remember we are fellow customers not sky and know nothing about your set up unless you tell us.
MikeAlanR
This message was authored by: martswain
Re: Tv stream box
Others have reported this issue and it was down to an older model TV not supporting the output the Stream puck was providing.
Try another HDMI input on the TV and see if there are any options in the TV menu regarding inouts.
