Discussion topic: Turn on Sky stream to a satelite channel
Message posted on 11 Aug 2024 05:18 PM
It has bugged me that this is not possible. Its partly because I sometimes turn on my system from another room, and worry about screen burn with the relativley static home screen.
I use a flash universal remote with macros (I have a URC MX980, but Harmoney etc should do the same.)
The macro below seems pretty reliable and takes a puck that is on and sets it to c404.
Might be of help to someone ?
Home
2 secs delay
Down
Down
Select
Select
5 secs delay
Down
Down
Down
2 Secs delay
4
Select
Select
Message posted on 11 Aug 2024 06:47 PM - last edited: 11 Aug 2024 06:48 PM
Re: Turn on Sky stream to a satelite channel
I am sorry what does this mean ? What do you mean "turn on sky stream to a satellite channel ?"
Message posted on 11 Aug 2024 07:16 PM
I mean like Sky HD used to, when powered on it goes to a channel rather than the home screen.
Message posted on 11 Aug 2024 08:23 PM
Hi @kdp99
You can not set steam to load a TV channel. You will always land on the home screen. However pressing left will show you recently viewed channels and center button will take you to it. Slightly quicker than going via TV guide or you can press the mic button and say go to channel x.
For reference Stream is not a satellite product, all content live and on demand is delivered by broadband / IPTV.
MikeAlanR
Message posted on 11 Aug 2024 08:26 PM
Using this macro takes you automatically from the home screen to a desired satellite channel, in this case 404
Message posted on 11 Aug 2024 08:29 PM
As stated they are IPTV channels not satellite. Your puck is not connected to a dish. As stated the functionality built in for those using sky glass / stream remote is pressing left and using recent.
MikeAlanR
Message posted on 11 Aug 2024 08:38 PM - last edited: 11 Aug 2024 08:38 PM
That's actually rather clever: presumably the risk is that it can be broken at any point in the future by a UI change though.
Message posted on 11 Aug 2024 09:11 PM
... but works via IR😉
