Discussion topic: Travelxp and n Sky stream
This message was authored by: Ckennedy60
Hi Sky.  A request to put TravelXP channel also on Sky stream.  It's the only Q channel Non-Stream channel I watch at this theta houses but can't at mine as I can't get Q but can get stream so please put this in your requests for the future new channels on Stream
Re: Travelxp and n Sky stream
Hi @Ckennedy60  This is a customer help customer forum so you will need to contact Sky with your request.
I would suggest your easiest avenue would be to send an email to Viewer Relations at [email protected]
@Ckennedy60 Sky cannot add channels without their agreement so also make your suggestion to the channel owners. Given satellite broadcasting in the UK has a limited life many of the smaller channels will have to make the move to streaming before 2030
