Discussion topic: Technical fault despite rebooting etc
This message was authored by: Tut5
I am receiving technical fault all the time and interruptions to all channels despite rebooting turned everything off and reset and restarting
This message was authored by: J_ham
Re: Technical fault despite rebooting etc
Posted by a Sky employee
This message was authored by: baron75mk3
I just had the same thing , a full reboot seemed to clear things up , i did it from the settings page
@Tut5 Also i have done the suggestion that @SamK4 has suggested here
https://helpforum.sky.com/t5/Sky-Stream/Sky-puck-technical-faults/td-p/4945430
, only difference is on my router i can completely disable IPV6 , hopefully it will solve the issue
