Discussion topic: Technical Fault with this channel - Sky Stream
This message was authored by: DanieRivs
I have a Sky Stream Puck. This afternoon I started getting error message Technical fault with this programme. Please try again later. This is happening on all channels. I have restarted the puck and hub (several times) the puck is connected to the WiFi via Ethernet cable and there are no speed issues.  Apps are working without issue!  Any advice?
Re: Technical Fault with this channel - Sky Stream
Who is your ISP?
What is the router sync speed to the internet?
What is the connection speed measured by the Netflix app on your Puck to the internet?
Avatar for DanieRivs
@Exiled-in-HH
Hi - I'm with Plusnet.
My speed is 140.18mbps.
Netflix app is saying: 84.21mbps
That all looks good🙂
Have you tried power off at plug.... wait 2 minutes.... power on?
@Exiled-in-HH
That worked thank you!
Will keep an eye on it! 🙂
This message was authored by: Jonathanphillip
I've add that happen to me  your not the only 1 who as got it along with technical fault @DanieRivs
This message was authored by: MrNick
I have had this issue and been speaking to sky who just fob you off as it's an issue and they are working on it. Yet they advertise it like there is nothing wrong.
But I have found if you turn off/disable IPV6 on you internet it's much more reliable. Still get the error on some certain channels but it definitely helps.
