Discussion topic: TV won’t turn on using remote
This message was authored by: DestroyertheN4SA
The first time in the day everyday the TV completely refuses to turn on via. the remote. The remote works fine throughout the day after that but then the next day the same thing the remote won't turn on the TV the first time you use it.
Re: TV won’t turn on using remote
You could try disabling overnight power saving mode in the settings and see if this helps.
Avatar for DestroyertheN4SA
Level 2 icon
Thanks. Just disabled that setting. Let's see. Fingers crossed.
