Discussion topic: TCL 55” Connected to Sky Stream
This message was authored by: Steve93
Above TV connected It works the volume up & down but doesn't switch the tv off,  anyone know what make of tv I can use so it'll switch it off
Re: TCL 55” Connected to Sky Stream
@Steve93 wrote:
It works the volume up & down but doesn't switch the tv off,  anyone know what make of tv I can use?
Have you tried a long press of the standby button on the remote?
Avatar for Steve93
Level 6 icon
Yes but doesn't switch it off, thought you could use a well know make
This message was authored by: Hunter2660
Out of curiosity is it a Fire TV or Google OS. If it's a Fire TV just say "Alexa, switch off TV". If Google just say "Hey Google, switch off TV". Job done.
Avatar for Steve93
Level 6 icon
It's a Google Android tv
I presume it has voice control in the settings?
Avatar for Steve93
Level 6 icon
Yes it does
