Discussion topic: Switching from sky stream to sky glass
This message was authored by RosieClay1996 This message was authored by: RosieClay1996
Hi, I'm looking to switch from sky stream & getting sky glass. I can't seem to get on the right track about it, any help will be great. Thank yiu
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Switching from sky stream to sky glass
@RosieClay1996
I have moved your post to the Glass / Stream board as it's not a Sky mobile issue. Someone with Glass or Stream should be able to give you some advice.
@RosieClay1996  You'd need to call Sky to do this, however if the sole reason is to get a new TV them perhaps considering a less expensive Smart TV and keeping stream would be the best solution.
