3
This discussion topic has been answered Discussion topic: Stream puck or The EE TV Box Edge
This message was authored by: Suffolk2020
 Looking to move home and currently have Sky Q but if we move sky dishes are not allowed so looking at Sky Glass. We currently get TNT sports & discovery via EE. If we move do I need the  stream pucks or the EE box edge devices ?
This message was authored by: Richardr1 Answer
Re: Stream puck or The EE TV Box Edge
If you move there is no reason you can't keep the TNT Sports via EE subscription and use the new HBO Max app for it [I assume you use the Discovery+ app today]. I've not seen so far what EE are going to do with the rest of HBO Max, so may be worth waiting to see.
The other things worth checking bnetween EE TV and Sky Stream:
  1. EE TV only works with EE Broadband
  2. check the channel list to make sure they both have the channels you want
Hi @Suffolk2020
If you get sky stream you won't get TNT via the EPG (Program Guide) - however you will be able to log in and watch on the Discovery+ App (or HBO Max from March as they are moving) unless you subscribe directly from Sky.
Given this is the Sky community can't advise on EEs TV offering but sure their community will be able to tell you about it. But that is an EE product and you would cease to be a Sky customer (and EE uses NOW TV to provide Sky channels).
MikeAlanR
Avatar for Suffolk2020
Thank you
