Discussion topic: Stream luck bulky power adapter
This message was authored by: Maclink
Hi, I have a socket mounted behind my tv that I intended to use to power my stream puck. But with the shape of the plug, it sticks out too far and now I can't hang my tv off the bracket as it is clashing with the power adapter. Is there an alternative adapter that can be used or one that plugs in at a right angle?
Re: Stream luck bulky power adapter
@Maclink  You'll need to either make your own extenstion or source your own from any electrical retailer.  Sky don't supply anythin g other than the standard plug/power brick.
Given that the 3 pin plug on the power brick is actually a standard size you may be hard pushed to fund simething thinner so you may need to use an alternative socket nearby.
