Discussion topic: Stream Technical fault
This message was authored by: Plungoer
Message posted on 16 Sep 2025 10:11 PM
Technical fault
All channels say technical fault try again later has been dong this since 21.05 nothing helping
This message was authored by: Jon34
Message posted on 16 Sep 2025 10:14 PM
Re: Stream Technical fault
Yeah cat8 is good, the signal quality is much better than the previous versions so fingers crossed for you
