Discussion topic: Spotify UI on Sky Stream
This message was authored by: TheMoxhams
Hi,
Could someone confirm if the Spotify UI on Sky Stream is the new updated one that arrived in November?
Thanks!
Re: Spotify UI on Sky Stream
@TheMoxhams currently the Spotify app on Stream is dated as 9/10/2023 so probably not the version you refer to. Apps on Stream run on Sky's severs rather than on the box so are updated as new versions have been tested by Sky staff.
Avatar for TheMoxhams
Do you have a screenshot to confirm this?
Thanks.
