Discussion topic: Sound
This message was authored by: Gary832
Sound
Every few minutes, the sound goes out of sync with the person talking, so have to turn off and back on the few minutes it happens again, can't watch TV properly as missing so much of the programs
Re: Sound
Hi @Gary832
This has been reported many times on the forum. See: https://helpforum.sky.com/t5/Sky-Stream/QS025-Lip-Sync-Issues/td-p/4607728
That thread has steps you can try to resolve.
MikeAlanR
Re: Sound
@Gary832  This is a known issue which Sky are trying to resolve but in the meantime they suggest changing your audio settings to PCM or Passthrough.
There is an extensive thread on the subject at this LINK
