Discussion topic: Sound issues on Sky Stream
Message posted on 18 Apr 2025 05:21 PM
Hi guys, having a little issue with sound seems to skip slightly only on Sky channels (freeview channels seem ok). Not sure the video does it justice. I've tried the usual reset and switch off at the wall for a couple of minutes but not sorted. It can be more noticable dependant on what we're watching. Any help would be awesome. TIA
Message posted on 18 Apr 2025 07:01 PM
Re: Sound issues on Sky Stream
Hi
are you using an external sound system ? If so which one and how have you got it linked ? Some points to consider ..... use the dedicated hdmi earc port
also try swapping sound output between the various options available (auto, pcm etc)
Message posted on 18 Apr 2025 07:15 PM
No external sound system, sound direct from the TV. I'll give the swapping the sound output around. Not sure about the dedicated hdmi earc port I'll have to check. I;ve got 3 or maybe 4 HDMI ports on my TV. Thanks for your help I'll update if this sorts it
