Discussion topic: Sound box and sky puck
This message was authored by: Andy--
I am looking for a good sound bar for my sky puck.
I currently have a sky sound box but the voice sync is always out
This message was authored by: Dazzasky
Re: Sound box and sky puck
Basic rule is the more you spend, the better it is. Make sure it supports HDR UHD. @Andy--
If your TV has ARC (or better still, eARC) capability then look for a soundbar with similar. This will allow you to connect the puck to your TV and have the audio pass through to the soundbar via HDMI eARC.
Some soundbars have HDMI inputs too. If you get one like this and want to connect the puck directly to it instead, make sure it has full 4K HDR passthrough available. Some soundbars can be slow at waking up from standby. This can interfere with the HDMI handshake between the puck and the TV so take that into consideration too.
Also look for Atmos capable soundbars if you want the best possible audio option from Sky Stream.
