Discussion topic: Sly Stream and Ethernet
This message was authored by: Scottydog76
Connected to ethernet (ethernet plug into an electrical outlet) since setup for a few months. Yesterday (21st June)  I received a technical error message and was unable to watch TV.
Disconnected ethernet and connected to Wi-Fi and it worked. Id prefer to connect via Ethernet but is there any reason it would have stopped working?
This message was authored by: Nigelb1972
Re: Sly Stream and Ethernet
It sounds like an issue with your Power line adapters rather than the box. You could try rebooting those by power cycling them
Avatar for Scottydog76
Yeah tried that but no joy.
I didn't power cycle the router however but just wondered if it was something to do with the Sky router or allocation of IP as my wi-fi is Google.
Stream should work with an router/isp. Have you tried connecting via ethernet directly to the router?
No mate, the puck is some distance away from the router.
It's been working fine since install for 2 months. I suspect it was the Ethernet plug but power cycled - maybe a glitch with the internal wiring of the electrics in the house?
I wouldn't have thought an electrical issue would suddenly arise, especially one that only affects your Power line adapters. I'd try connecting the Puck directly to your router temporarily just to run a test so that you can rule out a ethernet issue with the router.
Will do - just realised the misspelling of this post 😅
Sky (Sly) Stream gets called all sorts on here so regulars tend not to pay attention to weird titles ect 🤣
@Scottydog76 I have used various powerline adapters for years. They are great when they work but they can suddenly stop for no apparent reason. Leaving them unplugged for a while has worked for me in the past as has oddly switching the different wall socket. Of course dont use trailing adapters if at all possible.
