Discussion topic: Sky stream
Message posted on 17 Sep 2026 04:42 PM
Sky stream
My sky box keeps saying technical fault I have switch it off by the plug for a good half an hour and
the Home Screen shows up the tv guide shows click a channel and I get a technical fault
Message posted on 17 Sep 2026 05:21 PM
Re: Sky stream
I'm also having the same issue
Message posted on 17 Sep 2026 05:35 PM
Re: Sky stream
Me too. This is only on broadcast channels though. Apps (Disney, iPlayer, Prime , Netflix etc.) all seem fine.
Message posted on 17 Sep 2026 05:40 PM
Re: Sky stream
Experiencing the same issue. Anyone has their's restored?
Message posted on 17 Sep 2026 05:41 PM
Re: Sky stream
Can we have a bit more detail please on this issue.
Has this just started today or have you had it for some while?
Could you list your UI version in Settings>Systems Management.
Even if you have done so today, can you do a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Message posted on 17 Sep 2026 05:44 PM
Re: Sky stream
UI version is 3.301.2
Message posted on 17 Sep 2026 05:52 PM
Re: Sky stream
Also having same issue says good internet connection as also reset that apps like Netflix work but non of the channels.
Message posted on 17 Sep 2026 05:57 PM
Re: Sky stream
Done this but live tv still not loading showing as failure to load again. I have same hi number as other person.
Message posted on 17 Sep 2026 05:58 PM
Re: Sky stream
Me too
Message posted on 17 Sep 2026 06:00 PM
Re: Sky stream
For my it was working find this morning, I noticed the issue this afternoon - all sky stream channels are displaying the following error:
There is a technical fault with this programme. Please try again later.
I've performed broadband tests and reset the puck to no avail.
confirmed the built in apps like Netflix are working via the sky puck just seems to be issue with sky stream channels.
UI version = 3.301.2
Message posted on 17 Sep 2026 06:01 PM
Re: Sky stream
Message posted on 17 Sep 2026 06:05 PM
Re: Sky stream
Same here
Message posted on 17 Sep 2026 06:21 PM
Re: Sky stream
So this is definitely not an isolated issue..looks like its affecting many..Will sky issue any notice or fix?
Message posted on 17 Sep 2026 06:32 PM
Re: Sky stream
The only apps that is working Netflix is working
Message posted on 17 Sep 2026 06:35 PM
Re: Sky stream
Got the same problem
