Discussion topic: Sky stream
This message was authored by: 28Steve
Sky stream
I'm stuck on updating software.
Re: Sky stream
Pull the plug. Leave it off for a minute then power it back on and try again. It's often also worth connecting to your router with an ethernet cable until the update is complete. You can then hopefully switch to using WiFi.
Re: Sky stream
Assume this is when setting up a Sky Stream puck.
Follow the Sky help article here and do as it says on step 4;
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-strea...
