Discussion topic: Sky stream
Message posted on 17 May 2024 11:40 AM
Sky stream
Sky stream remote keeps failing
Message posted on 17 May 2024 01:10 PM
Re: Sky stream
@Garymydog Here are some things to try 🤞
To help you try to get your remote working the links below are to remote related troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement. I use one as a secondary remote.
