Discussion topic: Sky stream
This message was authored by Ants29 This message was authored by: Ants29
Sky stream
Hi
I currently have sky hd + , tried to upgrade to sky Q which unfortunately couldn't be done as we needed a new dish and permission frI'm landlord to install new dish etc
hence I am considering to go for Steam as I have good broadband speed pls can you share your view , a pros and cons for sky stream
thank you
Re: Sky stream
@Ants29  Feel free to have a read through the many freely available threads both good & bad to get a flavour of the good & bad points of stream.
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Re: Sky stream
Why did you want to change to Sky Q is your Sky+ HD box starting to fail?
What aspects of Sky Q or Sky Stream attracted you?
If you wanted access to streaming services other streaming devices work with far fewer issues ... unless you're of the lucky ones who receive a Puck that works🤔
Exiled in HH
