This discussion topic has been answered Discussion topic: Sky stream remote
Message posted on 25 Feb 2024 09:10 PM
Is it possible to get a replacement remote for sky stream,ours had something spilt on it now it won't work
Message posted on 25 Feb 2024 09:25 PM
@Jason70You can request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
