Discussion topic: Sky stream remote and puck not connecting
This message was authored by: mac96
Hi, I'm having an issue with connecting my Sky stream remote to the puck.
I've only had it a few days and it worked fine initially, but then a message came up that the remote has unpaired and that it needed to be reconnected.
Since then nothing has worked.
I tried the holding 7 and 9 and then holding 1 and 3 dozens of times - nothing.
Checked remote batteries (they are fine and the remote backlight works).
I unplugged the puck at the mains multiple times, and even did a factory reset.
Thought the problem was with the remote so got a new one from Sky - no different, exact same issue. Removed the batteries from the first remote to ensure no interference there.
I wonder if there's an infared connection problem with the puck as it just doesn't seem to recognise any remote.
Would welcome any help! Thanks!
This message was authored by: Jporch316
Re: Sky stream remote and puck not connecting
@mac96
Try the following
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
If the normal repairing off Press and hold 7 and 9 together for 3 seconds, Press and hold 1 and 3 together for 3 seconds, does not work, try the following;
There have been issues in the past that  the remote firmware has not updated correctly;
Try this.
  1. Pair your remote control to your puck (by pressing 1 and 3 for 5 seconds).
  2. Once you've seen that the pairing has been successful, switch the puck off at the wall socket.
  3. Plug the puck back in and leave it switched on for a minimum 15 minutes.
  4. Switch the puck off at the wall socket for a second time.
  5. Power the puck back on and continue to use the service, allowing the puck to go into standby as usual overnight.
Try this.
I have bookmarked your post @lettice as that's an interesting procedure I had not come across before.  I will try it next time my remote plays up and maybe suggest it to others having issues 👍
