1
This discussion topic has been answered Discussion topic: Sky stream puck standby issue
This message was authored by: screaming+eagle
Every four hours Stream Puck turns off , why ? If this is some lame attempt to save power then it just doesn't ,simply all it does is makes me regret giving up my Q , any advice?
thanks in advance
This message was authored by: Angel_Aka Answer
Re: Sky stream puck standby issue
@screaming+eagle
It's a 'thing' with Sky Stream. The puck will automatically go into standby if it detects no interaction from the customer (ie no button pressed or movement of the remote.)
It's some kind of energy saving edict which cannot be over-ridden.
@screaming+eagle
