Discussion topic: Sky stream puck no video issue
Message posted on 23 Oct 2024 07:19 PM
Hi all,
Switched on the sky stream puck and my tv today. Puck loads the Sky home menu fine but when I select live TV/any app (Netflix etc)/catchup. It loads the content but only the audio plays. The program 'timer' ticks along as if it's playing but no video plays. No screen flickering or any hdmi issues encountered.
Have tried normal restart, factory reset, changing video and audio settings.
Fresh out of ideas! Any help will be well received!
Message posted on 23 Oct 2024 07:55 PM
Re: Sky stream puck no video issue
Now seems to not play audio either! Sometimes when turning it off then on again I get audio, other times none! Video never seems to work..
Message posted on 24 Oct 2024 07:37 PM
Hi @MeMeuop
I have escalated your post to the online sky community support team ..... please lookout for an invitation to chat with them
Message posted on 25 Oct 2024 09:56 AM
Thanks for escalating. We've sent an invite to @MeMeuop.
Tom
Message posted on 30 Apr 2026 11:12 AM
I have this issue too. Puck has never worked properly from first install. Have to do several mains power off at the wall to eventually get video. No other streaming deivce has this issue.
What's the fix?
Message posted on 30 Apr 2026 04:51 PM
Hi, I get the same, or similar.
Picture freezes and eventually goes to a solid light grey screen, but audio contines.
Going to 'Home' and back in, does not solve the issue.
New puck (due to playlist not working - sky say this is a known issue, but refue to say what the issue is or when it will be fixed)
Moved to Sky fibre 100mb broadband.
Puck plugged directly into Sky router, which is plugged into ONT, all within a metre of each other.
So everything is with sky.
Still getting these issues, yet sky just put all the prices up!
Should also add, far fewer channels on stream than on normal sky.
If I have helped, please click the thumb 🐵
IT & Telecoms professional, Bsc, Hsc 33+ years experience. Hands-on, installation, maintenance & troubleshooting
Qualified (Level 3) Electrical Engineer
Sky from Astra 1989 > sky digital > Sky Hd > Sky Q
