Discussion topic: Sky stream puck freezing
Message posted on 05 Oct 2025 09:54 PM
Our sky stream puck keeps freezing when trying to navigate through the sky pages/channels. Every time I go to change channel I then have to switch the puck off at the wall plug and leave for 10 minutes before turning back on, but even that hasn't been working recently which is becoming increasingly fristrating. Our internet connection is absolutely fine and the pick is connected to it via an ethernet cable. There is nothing around the puck to cause any interference. Can anyone offer any advice or could we have a faulty pick?
Message posted on 06 Oct 2025 07:06 AM
Re: Sky stream puck freezing
Hi @Dreed90
maybe try with your wifi instead of the ethernet cable.
what speed is your internet connection ? You can find out by going to Netflix - settings - network test on your puck
Message posted on 08 Oct 2025 08:52 PM
It doesn't look my internet is the problem, I have speed of 90 Mbps on WiFi and then 149 Mbps via ethernet cable. It still freezes whether the ethernet is plugged in or not. Also had the sound cut out today whilst I was watching something.
Message posted on 08 Oct 2025 09:44 PM
@Dreed90 wrote:It doesn't look my internet is the problem, I have speed of 90 Mbps on WiFi and then 149 Mbps via ethernet cable. It still freezes whether the ethernet is plugged in or not. Also had the sound cut out today whilst I was watching something.
Make sure you switch off WiFi in the settings then do a restart in system management in settings to save it. Then the Ethernet should work
Message posted on 12 Nov 2025 09:36 PM
Tried this and it's still freezing intermittently. Had it cut out whilst we were watching a programme twice this evening, and then have to keep switching off and on again at the mains to get it started again. Very frustrating considering the amount we pay for it every month. I've seen on other forum threads that people have had success with new picks, is it possible for Sky to send a replacement?
Message posted on 12 Nov 2025 09:47 PM
@Dreed90 wrote:Tried this and it's still freezing intermittently. Had it cut out whilst we were watching a programme twice this evening, and then have to keep switching off and on again at the mains to get it started again. Very frustrating considering the amount we pay for it every month. I've seen on other forum threads that people have had success with new picks, is it possible for Sky to send a replacement?
Yes but you would need to call sky for troubleshooting first.
