Discussion topic: Sky stream puck disconnecting repeatedly
This message was authored by: DeniseDoolin
Message posted on 11 Dec 2025 08:50 AM
Sky stream puck is freezing the screen disconnecting and saying there is a fault
This message was authored by: Stephen+Mourton
Find out more
Message posted on 11 Dec 2025 06:00 PM
Re: Sky stream puck disconnecting repeatedly
@DeniseDoolin The usual reason is either a poor internet speed, or more likely your set up. If you are not connected via an Ethernet cable then ensure your router and Sky puck have a clear line of sight with nothing blocking the signal such as furniture. I hope that helps.
