Discussion topic: Sky stream puck activation issue
This message was authored by: Amal23
Message posted on 28 Sep 2024 01:48 PM
Tried to activate my Sky stream puck for the first time. It requires a software update, which, after carried out displays a page that says "Not Supported!"
I'm using a Toshiba tv (model number: 32AV615DB)
This message was authored by: Jporch316
Find out more
Message posted on 29 Sep 2024 08:43 AM
Re: Sky stream puck activation issue
@Amal23 wrote:Tried to activate my Sky stream puck for the first time. It requires a software update, which, after carried out displays a page that says "Not Supported!"
Can you try running through the setup with the puck plugged into your router via ethernet cable. Once complete you can revert to WiFi
